So I got a AQ125a in a 21' trophy the boat was having a cooling issue where the motor would run hot after awhile (200-210ish) I parked the boat and was going to fix it later well that was 3 years ago I have finally found the time to pull it out and fix it so I got it running great after dealing with old fuel issues and what not..... I tore down completely the fresh water and raw water cooling systems on the boat I replaced all the gaskets, took off the exhaust manifold rodded out the water passages with some wielding wire looking for blockages then hooked a garden hose up to the tube on the bottom side of the manifold and checked water flow through the water ports into the elbow and everything flowed great out of all the ports and the flow looked pretty even as well, I tore down the heat exchanger and pulled out the element gave it a couple baths in muratic acid and water then pressured washed the inside and out then cleaned the housing it looked pretty clean inside. I pulled off the raw water pump cleaned it all up and replaced the impeller the raw water pump housing appears to be good ( not sure what a bad one would look like) I also replaced the thermostat with a new 180 deg one. I cleaned the fresh water reservoir tank as it had a little bit of gelling in it. I also replaced the cap on the top of the radiator as the gasket was worn and cracked... I pretty much did everything I could of think of to do as it needed it.... Well I got everything back together and ran the boat in the driveway and noticed it didn't seem to be pumping enough water on the raw water side of things out the drive port. I took off the cap on top of the raw water heat exchanger and the sea strainer to look to see if there was water, I noticed the water level was to the top of the heat exchanger element but below the the hose port of the tube coming from the impeller pump. When I run the engine with the raw water cap off it will flow water up to the top of the neck of the raw water filler but not really overflow like I'm assuming it should do? If I cover where the raw water cap and sea strainer goes with my hand or put the cap on the water level will go back down to just over the heat exchanger element and blow the the tube coming from the impeller pump and appears not to be pumping water take my hand off it will fill up and flow some water but not near enough... I suspect I'm sucking up air somewhere but not sure where or how to find it I'm thinking somewhere near the impeller or the impeller itself but not sure any tricks, tip, or suggestions would be most apreacaited or if there is something I'm doing wrong or missing or something I should be checking... I'm not really good with I/O's this is the first on I have owned
Thanks for the input
