"Been reading here a lot but t
"Been reading here a lot but this is the first time I need to post. Go easy on me as I am young and delicate.
Here's the problem....... Just installed a new tilt motor and relays. On test leads tilt runs up and down no problems. When I go to the dash tilt switch, the tilt will pick the drive up but will not lower it and is blowing the ignition switch fuse.
Do you think the problem is in the tilt switch or in the tilt relays/micro switch. I have tested the ignition switch and it is good."
