Hi there can u please send me the same relay picture"Hi,
Please refer to the sc
"Hi,
Please refer to the schematic below, and:
1) Connect the red wire coming from the overload thermal fuse to 30.
2) Connect the other red wire (the one going to the start solenoid) to 87
3) Connect the yellow/red to 85.
4) Connect the black to ground on one side and to 86.
Can't open up the pictureHi there can u please send me the same relay picture
Also if you have starter silonide wire pics and ignition coil
Someone pulled my wires off and I'm not sure where everything goes
Please and thanks
I have a AQ120B volvo penta motor
Email me
[email protected]
Non EFI or TBI engines are pretty much all wired this same... The schematic bleow should be close enough for you get the job done.
Per upper left of dwg.... +12V feed from battery (Red)Thank you
So much
Another question
What wires go to the key switch
