"I’ve got a 1980 22’ Bayliner
"I’ve got a 1980 22’ Bayliner with an AQ120B engine and a 270 drive. The engine was running fine until I heard a pop. It ran fine again for an hour or so, then got very rough and finally stopped. I’ve replaced the points, plugs and, because I couldn’t see a spark, the ignition coil. It starts right up, but the RPM varies wildly and it needs to be coaxed with the throttle to keep running until it gets up to full operating temp. Then it runs, but rough, with frequent popping misfires. There is no backfiring through the carb.
When I put the timing light on it the mark is steady, but when the engine misfires the timing light doesn’t ignite as though there is no spark.
My plan is to look at the distributor rotor again and maybe replace the plug wiring.
The RPM variation makes me think that it may be fuel related, perhaps water in the fuel. This engine doesn’t have a fuel water separator or even a fuel filter that I have been able to find.
Any thoughts?"
Any thoughts?"
