When running in the driveway it runs smooth but unless I gas it slowly, it coughs and dies. The accelerator pump is new and not hesitating. I checked the timing and it was at about 30 degrees btdc at 800 rpm I corrected it to 10 degrees and it runs worse. There is no mark on the pulley so I made my own mark as best I could using a screwdriver down the hole and wrench to turn the motor. The carb is a solex side draft. I got a rebuild kit for it but it basically came with the accelerator pump, float valve, gasket and some different size washers. The carb is clean but I am going to double check it tonight. Compression is 190,180.190,175, seems like a ton but there is blow by while under load, but none in the driveway. I should add, the boat was sitting for years when I got it. It had dirty oil in it and compression was 120,110,120,95. After changing oil and running it for about 1 hour it had the compression readings before mentioned. Oh and new plugs cap points rotor.
