AQ120 fuel pump
dwight
Is there a fuel pump from a la
Is there a fuel pump from a later model Volvo Penta that will fit the AQ120? They want $400.00 each for them and I need 2.
Just a little input on your su
Just a little input on your subject. I have a 120B and I replaced the mechanical fuel pump with a low volume electric pump and manual pressure regulator. This setup works very well and costs a total of sixty bucks. I also carry an extra pump in case mine fails while on the water. good luck.
"Hey Dwight , I replaced the f
"Hey Dwight , I replaced the fuel pump on my AQ120-B and it only cost 70.00 . part #841161-3"
"We need to clarify whether we
"We need to clarify whether we are talking of an AQ120A or an A120B. An AQ120A is an OHV engine (B18 block) similar to a point to the AQ130, and the fuel pumps are expensive (the pump in the link is for the AQ130, not sure if it fits the AQ120A).
http://www.volvopentastore.com/FUEL_PUMP/dm/cart_id.657400424--category_id.33233 6--list_time.1206499638--session_id.029299349--store_id.366--view_id.317606
But if it is an AQ120B, it is an OHC engine (B21 block) similar to the AQ125, and the aftermarket fuel pumps are relatively inexpensive.
http://www.marineengine.com/parts/part_details.php?pnum=SIE18-7286&returntopage= sierra_marine/sierra00811.htm"
My engines are AQ120 1967? vin
My engines are AQ120 1967? vintage. The fuel pump has a glass sediment bowl attached to it. I have installed a large fuel filter with a water trap so can do away with the ones on the fuel pumps.
