AQ120 B pertronix install
79_galaxy
Hope someone can help me
I in
I installed the pertronix igniter and my engine ran great for a few minutes
then I gave it a rev it died and would not restart
I used an MSD Blaster2 coil
now I have 12 volts to both sides of the coil
I suspect it is traveling through the igniter any help would be appreciated
"If you have 12V at both sides
"If you have 12V at both sides that would indicate that the circuit in the ignitor is open. Did you use a 3 ohm coil? If yours is a 1.5 ohm or lower resistance coil, the ignitor could be toasted by now."
