The mechanic had the outdrive apart and walked me through the failure.
The top nut on the intermediate shaft had come loose and the top two bearings piled up from the filings. The cone clutch and pinion gears in the transmission are a dark colour...he figures the clutch had been slipping. Everything else looks good.
I purchased a complete upper drive...he is taking apart to ensure its all good, and am replacing the rest of the tapered bearings, seals, shims and gaskets. He has the re-shim procedure Riccardo has mentioned.
The question I'm putting out there is: Do you think my modified re-built 350 has too much torque for this drive?
