I believe I have seen a post like his before but I did not see any answers for it. I have an 84 bayliner contessa with the aq 260 in her. She was getting up there in hours so I replaced it with a new 300 horse Volvo pent 5.7 engine. When I first bought her I could not get her above 2000 rpms and did a full tune up and adjusted the point gap and timing then had no problems with her. I then switched to a new electronic ignition and again had no problems with her. When I got her back from the shop and was finally able to take her to the lake I cannot get her above 3000 rpms. The shop said they set the timing at 2 degrees btdc and the manual says 8 btdc. What should the exact timing be for her and is there anything else I should look for. I brought her to the shop to fix the problem but it only does it under load and the shop guy never showed up at the lake to see what she was doing like he said he would before I had to get her out. I am hauling her down to Florida then taking her across to the Bahamas in about three weeks so I do not have a lot of time to have him try something then take her to the lake then him take her back then back to the lake etc.
Any help would be appreciated thanks
