AQ 151 oil pressure
my_heap
"I bought a used AQ 151 and it
"I bought a used AQ 151 and it seems to run up around 70 pounds oil pressure at cruising speed (2,800 RPM) Seems high to me if I really wind her up it will peg the needle to 80 pounds which is the highest the guage goes.
Maybe I got use to the old tired engine I had before. It ran half that pressure.
Is 70-80 pounds Ok???"
"According to Seloc, you have
"According to Seloc, you have a happy engine if the oil pressure is between 36 and 87 psi. In any case, you may want to double check with a Bourdon pressure gauge that the transducer and electric gauge are telling the truth.
"If it helps, my AQ151C sits a
"If it helps, my AQ151C sits at the top end of the gauge (80+) under cruise power. Now I would worry if it didn't
Tom"
