Aq 145a 280 tilttrim hoses
moby_dick
"Hi, I am new here and i have
"Hi, I am new here and i have a question on the tilt/trim hoses that run behind the exhaust pipe on my aq145a with a 280 outdrive. One hose i can remove with a wrench and the other seems like it is fed through the transom to a fitting, it has silicone all around the hose where it connects to the transom. I peeled the silicone off of what i could and it seems like the hose goes through the transom. is that the way it is supposed to be? I have a seloc manual and it does not go into much on my style of tilt/trim. They have a lot on the style that looks like a distributor. Also i can't seem to find a good drawing on the hoses. I ordered what i thought were the right ones, but they were real short. I need the ones that are about two to three feet long. can someone help me please?"
YES THEY ARE THE SAME AS THE L
YES THEY ARE THE SAME AS THE LATE PUMP. DOUG RUSSEL IS THE PLACE THAT I GOT THE HOSE FROM. I ORDERED PART NUMBER 12. THAT HOSE IS ONLY ABOUT 8 TO 12 INCHES LONG. THE ONE THAT I NEED IS MUCH LONGER
I am new to boating and I have
I am new to boating and I have a AQ131D with a 275 stern. While I was on the lake the other day the motor lifted with out me doing anything and then it went down when I increased speed going forward but when I put the boat in reverse the motor lifted again. Any ideas why this would happen and how to fix it. I am afraid to take the boat out again because the motor might not go down. I can not put the motor down with the titl switch.
