I would like to use a system l
I would like to use a system like the newer bravos use for raw water pick on my alpha.(eliminate the impeller) the question is do I simply remove the alpha impeller once the engine driven pump is installed? will the new pump pull the water up through the original ( impeller slots) or do I need to put some sort of extra water pickup on the drive?
