C
C Hilbun
Guest
" Hi all, i have a 112hp Johns
" Hi all, i have a 112hp Johnson outboard that was rebuilt just before i purchased it. I double oiled it to break it in and it runs fine. However, when it is in idle, it will run fine for five sometimes fifteen seconds and then it will start choking and the motor will die unless i give it some gas. Im wondering if the double oil has fouled the plugs and that they are the only thing i need to replace. Or does this sound like a carb problem? I need ti size up the situation before i go "fixing" the problem. Also the tale tell usually works but sometimes when idling it dosent pump any water until i give it throttle. But other times it pumps just fine while i am monitoring it and the idol. What could this be? Any and all comments are welcome and i thank all of you in advance for your help! "
