bruisedreed
I found a little Johnson 15 (J15rcrm) last season that was too good of a deal to pass on. I never managed to get it running well enough to use more than a time or two last season. I am quickly getting frustrated with it and am a bit perplexed with the way it behaves. I believe the main issue has to be a sync/linkage thing. I have good compression, a freshly rebuilt carb that delivers fuel well and an otherwise proven fuel system, Good compression even on both cylinders and good fire. I can start the engine pretty easily when it's cold by choking and advancing the throttle plate past the mark to open the throttle a little. Once started it runs, idles and works fine. Once shut down it will NOT start again warm. I have tried to sync the carb per instructions aligning the throttle plate mark and tuning the cam follower but it won't start and run in that scenario. It will quickly fire but dies immediately. I am open to suggestions at this point.
