"Hello to everyone. I found th
"Hello to everyone. I found this board and was hoping that someone would be able to answer a few carb questions. Heres the story:
About 2 years ago i bought a '98 4.3 out of a salvage yard. Rebuilt the engine and got it all together (also rebuilt the carb). IT would start right up, accelerate very well and perform well at any speed where the boat was on plane. Thats about 2700 rpm and up. The problem i was having was at speeds above idle like going thru slow speed zones. About 1000 to 1800 rpm. At those speeds the rpm would sometimes fluctuate like i hit the throttle or backed off the throttle. I couldnt seem to figure it out so i took the carb off a 3.0 lx. The motor runs good at all speeds but just seems a little different than the first carb. It doesnt seem to accelerate as fast with the second carb. Even when cruising at 3000 rpm if i wack the throttle it doesnt seem to have the same response as the first carb. IT does run better in the slow speed zones.
1. What is the difference between a 2bbl mercarb off a 1993 3.0l
lx and a 2bbl mercarb off a 98 4.3lx.
2. Any idea why i cant get the one from the 4.3 to work properly in the low rpm's?
thanks in advance to whoever would like to take a stab at this one."
