so i bought this boat from someone who lived on a causeway with a lot of silt. so much he could only go out a max of 4 hrs, 2 hrs before and 2 hrs after high tide. so the boat runs great but when you try to winterize it and run it on muffs, it wont push the a/f through. you have to break the whole system down, pull the thermo housing, and pull the quick connects on the block, ( its a 5.7 MPI with standard cooling and quick drain system.)
i bought a closed cooling system for it but before i just through this thing on, i want to be sure i can get the fluid to through the block properly.
i was going to knock out the expansion plugs and manually clean it out and i have already pulled the manifolds to get better access but of course, 2 lugs are behind the motor mounts. i do not plan to pull the motor but i may rig it up and pull 1 mount at a time.,
im just curious if anyone has any better ideas.
the engine is only a few years old and it only has abut 50 hours on it, otherwise i would just ride it out.
