Any help 99 johnson key switch
dano321
"last trip of last years seaso
"last trip of last years season my key switch went out. 1999 johnson 70 HP. I then took out the broke one, Smart move lol..... Anyone know how the wires hook up?"
"We assume that you have a ign
"We assume that you have a ignition switch with the following marked terminals.
Raised M, Regular M, B, A, C, and S. If not, what do you have?
What colors are the wires?"
Ok I have 6 wires #1 Red with
Ok I have 6 wires #1 Red with purple stripe #2 Yellow with red #3 Black with Yellow #4 Black with white #5 purple #6 purple with white......... On the back of the switch I have B A S C M between B&A and M between B&S Thanks to everyone........
Red/Purple__: "B" &#40
Red/Purple__: "B" (Battery) 12 volt source.
Yellow/Red__: "S" (Solenoid) Activates Starter Solenoid when key is in the START position.
Black/Yellow: "M" (Magneto) Raised boss "M" Terminal. Leads to Kill Circuit of Powerpack.
Black/White_: "M" (Magneto) Regular "M" Terminal. Are you sure this wire is Black/White and not just plain black? Leads to Ground.
Purple______: "A" (Accessory) Anything 12 volts would be applied to when key is in the ON or START position.
Purple/White: "C" (Choke) Activates Primer Solenoid when key is pushed in.
(Other members) Any comment on the Black/White wire scenario? I retired some years before this engine was manufactured and I'm not familiar with this wire color code.
Hey Joe thanks alot.........Yo
Hey Joe thanks alot.........You dont live around Erie do ya? And one more thing what do you mean by Raised boss M and Regular "M".. On the back of the key I dont see a diff on the M'S?
"Do You have the old lock with
"Do You have the old lock with screws (the one Joe referrs to) or the new one with pins? However the marking is as Joe describes, You may put black/yellow and Black/white to any 'M' pin."
Appreciate the jump in Mort. I
Appreciate the jump in Mort. I'm not familiar with the ignition switch pin setup. Always willing to learn something new.
"Joe:
as an additional commen
"Joe:
as an additional comment to this switch, introduced around 94 together with Deutz contacts, (no more Amphenol plugs) even has a built in emergency stop, eliminating the old safety switch. The safety lanyard is hooked straight on between key and lock, and if pulled key jumps mechanically to stop and cuts the engine. This system allows You to start and run the engine without the safety lanyard attached. Positive if the driver falls overboard with the lanyard, the crew may restart and pick him/her up."
