thostorey
"From fiddling with the raw wa
"From fiddling with the raw water outflow pipe at connector, part 18, I have sprung a leak from around the edge of the connector and this is the glycol/water mixture. To get this properly sealed I must remove the entire cooling system from the engine. When disconnecting the raw water inlet, will I disconnect at part #22? And, when disconnecting at the thermostat housing, part #31, will I disconnect at the engine block or at the heat exchanger? It seems that the block would be where but I'm far from sure.
This diagram is not exactly the same as an AQ151 but is should do.
http://www.volvopentastore.com/HEAT_EXCHANGER_AND_WATER_FILTER_WITH_INSTALLATION _COMPONENTS_AQ131A/dm/cart_id.657400424--category_id.332893--list_time.121185038 6--session_id.106479808--store_id.366--view_id.324024"
