Old Machinist
Well, to start. This is my first post. I will try to keep the stupid questions to a minimum. I'm working on a 1987 88HP Evinrude (E88MSLCUS). I bought the boat with gearcase in a box with impeller off. Put new impeller in it and reinstalled gearcase. just to find it won't fire. replaced starter to fix that problem. Went to lake to try out. Won't run past about half throttle, power flattens out, can't get it on plane. I have 130 lbs compression ( give or take 5 lbs ) on all cylinders. I have a good blue spark, jump over 1/2" on all cylinders. I have soaked carbs in Berryman's carb cleaner, cleaned and squirted choke cleaner thru every passage on carbs. When I went to pull flywheel off I noticed a little slack side to side in top bearing. Went and felt for slack on running 115HP Evinrude I have and, feel none at all. I don't know how much play is expectable in the bearing. From looking at bearing in pictures online. I guess little to none. I think I need to replace. With the price of a new one at $350 dollars I would like someone else's opinion on that.
That being said I'm not sure how that would cause the symptoms I am having. Here is list of my symptoms.
hard to start
from back of motor, looking forward, Left bank plugs look good, Right bank plugs RICH
in water at lake it will run up to about half throttle then flattens and won't accelerate any further
have good compression, good spark , clean carbs.
fresh fuel in tank
Any enlightenment greatly appreciated. I have about run out of ideas
Thanks in advance
Old Machinist
hard to start
fresh fuel in tank
Thanks in advance
Old Machinist
