I have a 94, 90 hp Mercury outboard. I have found that the oil level warning sensor is missing from the tank. My warning horn never made a sound. I tested it and it works. I relocated it from the control housing to under the dash to be able to hear it bertter. Started getting a short solid beep when the key was turned on to test the temp. circuit, but nothing else. Now, all of a sudden, I get the short beep with key on and a constant beep, beep, beep with the motor running. the beeps increase in frequency as the rpm's increase till it becomes a steady beep at about 3000 rpm. Above 3000 rpm the beeps stop. Oil tank is over 3/4 full, water is peeing out nicely, motor runs good. Oil sensor wires with bullet connectors from module are just there under the tank not connected to anything. Could this cause the beep, beep, beep? Since I don't have the oil sensor, should I connect the sensor leads together? Would that stop the beeps?
