Long story short, i have water in oil that comes in fast( 2 qt in 10 min).
i was doing a coolant pressure test, First one after an oil change hoping water in oil was a fluke, and forgot to empty water out. When i pressurized the system water came gushing into intake to starboard side intake ports.
Then when i emptied the water it just hissed at me.
Im pretty sure the manifold is shot but if anyone can explain another reason for the water shooting out with air pressure to where it doesnt belong??
Im confused because there wasnt any water in the cylinders prior to this, so if intake manifold was the issue why were cylinders dry ( water was in sump not in cylinders originally).
is there a reason other than rusted out intake manifold that the water would have blown into dry part of the intake under pressure 15 psi. Unless i blew out ( already compromised ) Manifold. But still, dry cylinder before this????
I guess the intake manifold wasnt the problem but is now.
Any insight would be greatly appreciated
