77galaxy
After installing lower shift cable and doing the cable adjustment i found a problem. while in nuetral trim doesnt work in up position only. If i move the shift handle forewarda little it works. From what i understand the trim switch should work in any position Forward, nuetral, and reverse. Looks like a position switch is mounted on the shift plate. the blue wire "up" circuit runs through this switch. Is this just out of adjustment???
