I have twin 305's in my boat. They are 1986 (or maybe 1985 have to confirm) year of manufacture. 1,000 hrs, FWC run in freshwater.
I recently tested low compression in two cylinders which we determined was a bad head gasket. Pulled the head, found heads needed some work. Reworked heads, restored compression. Ran fine for a couple days then threw a piston rod.
The marina wants to send the motor to a local machine shop to have the rod replaced and have an overall inspection done on the engine. The cylinder walls still look very good. I'm thinking the engine is going to get there and they're going to find more that needs to be replaced so it seems to me that the most logical approach would be to replace the engine with a reman from 1800runsnew.
The marina won't even quote me a price to do the swap, they say the price will be determined by the amount of labor required which they really can't quote up front because they're not entirely sure what they're going to run into. This obviously concerns me as a $1k head job turned into a $2,800 head job because 10hrs of labor turned out to be 22hrs. I am (unfortunately) married to this marina as they are the only game in town for where the boat is located.
In the meantime I am using the boat on one engine and while it's not ideal, I am comfortable maneuvering it on one engine. So, if it takes a week or two I can live with that. I only plan on owning this boat for one more season before I sell it, and I put on about 50hrs per season.
Looking for advice/suggestions.
