1960Dorsett
I recently purchased a new distributor drive belt as the original was looking a bit worn, and being at least 58 years old felt that it could use an upgrade. Removed the flywheel, stator, distributor, and bracket. Decided to disassemble the distributor to clean the parts, and bearings. There are three bearings in the distributor housing, one large needle bearing, and two ball bearings. the needle bearing seems to be in good condition, however the lower ball bearing feels kind of jankey after washing in solvent, so i'm ordering new ball bearings. My question is what type of lubricant is used for these bearings? It looked like some type of brown grease was used on the ball bearings, however the needle bearing looked like it had some kind of oil on it, and the Seloc repair manual I have doesn't address these bearings, or what is used for lubricant.
thanks for your consideration,
Mike.
Mike.
