downwindtracker2
Here goes another not peeing question. I changed the impeller when I swapped bottoms('76) on to a '75 top. Last Monday I took it out for the first time around the lake.It was dripping ,not peeing.When I pulled out,it was barely warm. Even in the barrel the pressure wasn't all that great,since the cowl was off I just pulled the tube to check. What are the usual things to check.BTW the old impeller was solid, just half the vanes were backwards.Could be why the motor was seized?? The '75 top while having 130+ compression, was used in the salt chuck.
