Here we go.
I've gone through about every no oil alarm thread I could find on this forum - my problem seems to be a weird one. 1993 Evinrude Intruder Spitfire Series 150. Model VE150GLETG, serial G03238408.
The problems started when the rectifyer/regulator burned. Actually burned off two of the three wires & melted the resin that seals the regulator. Replaced the regulator, tested the battery & test ran the motor on the trailor. Was showing 12.5 volts at the battery without running the engine, 14.5 volts at 1500 rpm. Had a load test done on the battery, all checked out good. Other than the usual one beep when starting the engine, I didn't notice any other alarm. Headed out for a tournament, launced the boat & noticed that the "NO OIL" alarm (one beep per second) was sounding. Checked the oil tank - full. Squeezed the oil tank bulb, the bulb was firm & squeezing it didn't shut off the alarm. Had blue oil exhaust & temp gauge was reading normal so I suspected that we were getting oil, but switched over to my kicker tank (mixed) just to make sure. Started working on the motor after getting home. The VRO pump seemed to be working, but I had an OMC mechanic tell me that it was possible that the regulator shorting may have taken out the "brain" on the VRO pump resulting in the alarm going off & that I should replace the pump assembly. I put a new one in, along with the new pulse limiter for about $400. Funny, the alarm was still sounding. At the request of the mechanic, I ran the motor with the premix & alternately unplugged the three tan wires controlling the oil alarm. Unplugging the tan wire right below the starter solenoid shut the alarm off. If I have traced that wire correctly, it appears to go into the harness plug that connects to the port side connector at the top of the power pack. Now, the mechanic says I should put in a new power pack. Not a problem, but what if the new power pack doesn't shut off the alarm? I am having a problem hearing or feeling any "clicking" noises from the VRO pump, but it does seems to be pumping oil.
Any & all help would be appreciated, this has been going on since July.
