tight_lines
On the way back to the boat la
On the way back to the boat launch the other day I ran the motor(1995 50HP Johnson) out of fuel less than 200 meters from the launch. I switched over to the other tank and it ran fine to the dock but when throttled down to idle it stalled and has had this problem ever since. The motor ran flawlessly till running out of fuel so I figured it must have picked up some debris form the bottom of the tank. Today cleaned and rebuilt the carbs and they appeared to be spotless as I just did them in the spring. After re assembly it seems to be worse as it won't even idle on muffs in the driveway and is running real rough. I set the idle mixture scews at 3.5 turns out which is the baseline given in the Clymer manual for these carbs and adjusting them from there doesn't seem to help(less smoke obviously when leaned out but still won't idle without the assistance of the fast idle lever). Any suggestions would be greatly appreciated.
