1973browning
"I recently bought an aftermar
"I recently bought an aftermarket alternator kit and Pertronix electronic ignition system for my 1988 3.7lx 180hp (470). In the process of putting the alternator kit on the engine I had to remove the power steering pump to attach high pressure hose fitting to power steering pump in order to have enough room to work. Anyway, I noticed that the power steering pump had a little front to back play when I pulled on the pulley in and out away from pump housing. Question: Should the pump have any forward,backward play. There is no side to side play just front to back. I just don't want to mount the pump and end up broke down on the water. Finally, the power steering pump is a NLA part and if you could get a new/old part they run around $350. What is the difference between an automotive power steering pump and a marine power steering pump? I could almost swear it looks like the power steering pump out of a 1980's Ford 351-M less the mounting bracket. Do marine power assist pumps run at the same psi as auto power steering pumps? Any help would be appreciated! Thanks, Tom"
