Good afternoon
Stbd Eng will not idle - Unfortunatley for me I forgot to remove the Neg Bat cable - and then sparks flew- no crank - no spark
There is no wire from the Ign Sw going to the Sol - There is a larger red wire coming from the Wiring Harness going to the Red 40 push button circuit breaker and then a wire going to the S side of the Sol.
Took a wire from the Bat to the Ign Sw and from the Ign Sw to the Sol. Turned key Eng cranked and then melted the Neg Bat Post Now no. Crank
Starting Circuit - Rebuilt Starter - New Sol - wires cables - Charged Bat - took wire from Bat to Sol = a few groans - nothing
Took this Starter and put it into the Port Engine - It cranked ok - Took all of components from the Port Eng and installed them into the
Stbd Eng - same as before no crank - SMOKE came from the Starter side of the Sol
This is where I am at any insight would be appreciated
