knight1852
"Hello friends
I am trying to
"Hello friends
I am trying to solve a operating problem of a 10 hp QD22s 1961. At first I thought it was a simple fuel system issue and i cleaned the crab well and I am sure that Now all the fuel passages are fine, however the issue still exists and it is this.
> You can prime the crab with the choke OR some extra fuel blow in to the venture and it will start fine. But as soon as you try to accelerate it dies. If you pull out the choke it will continue to run but not well. I also noticed some
“chip…chip ………chip“ sounds which seems to me misfire !! I also checked the firing and its fire from almost 1” blue!! Now I am a bit confused and don’t want to go further with out some valued comments and ideas from you guys …..<
Note: yesterday I noticed some air bbl inside the hose to crabs and in the glass filter under the crabs : fuel pump checked and found ok.
Do you think that the ignition system is fooling me and diverting attention to crabs? ACTUALLY THIS MOTOR WAS STROED FOR LAST 30 YEARS WITH OUT USE!!! May be the coils became weak? Some times they are not working properly?
thanks for reading and any of your comments are welcome.
kazi"
I am trying to
"Hello friends
kazi"
