badcrank 777
Good Morning all,
I have a crazy issue, and need help. I have a 17' runabout with a 110 Johnson outboard. I installed an Faria amp gauge and the usual from stator output to S on the gauge and I on the gauge to the positive battery terminal. All worked just perfect. I could hit the trim motor would show a discharge on the meter, running in the lake would show a small charge going to the battery. All very normal and working perfect.
Decided to install a seperate battery for some accessories, Used a battery isolator. Center terminal of the isolator connected to stator output, terminal 2 to the boat battery terminal 3 to the accessory battery. The terminal 2 of the isolator to the S on the amp gauge, I terminal from the amp gauge to the positive of the boat battery. Just as (or at least I thought) as it was before.
Issue is the gauge will not show any discharge when activating the trim motor, or slight charge when running on the lake.
What am I overlooking.
Thank you
Badcrank
Thank you
Badcrank
