Going to try one more time.....
Radio Shack: If whoever you're talking to there doesn't know what a two wire diode is that can handle 12 volts of a automotive battery, ask to speak to someone that does or visit another Radio Shack store. It's simply a diode that is about 1/2" in diameter..... they're readily available.
As a last resort ,sometime when I'm out, I may just stop in the local Radio Shack to get the part number but I'm not going to make a special trip for it.
NOTE that this is a diode that is easily recognized, fairly large.... NOT a small diode that one would find in a circuit board.
When/if you find the diode..... use a ohm meter to find the direction of voltage travel. In one direction, there will be no reading. There will be a reading in the opposite direction.
When you do obtain a ohm reading, whichever diode wire the ohm meter red lead is connected to..... that's the wire that should be connected to the pulsepack input voltage terminal if memory serves me right (usually a purple lead). If my memory is flawed, hopefully someone will jump in here with a correction.
Double check it before connecting the diode wire to the pulsepack terminal.... you want 12 volts at the pulsepack end of that diode wire when the key is turned to the START position. If there is no 12 volts present in the START position, reverse the diode.
The wire on the other end of the diode should be connected to the electric starter cable terminal of the starter solenoid, NOT the battery cable terminal.
Good luck.
