"I'm new to outboards and
"I'm new to outboards and fear my 4hp 1981 Johnson is getting too hot. I've checked the impeller and it's fine. I'm getting a small amount of warm water out of the tell tale hole's down the shaft, not a lot. I understand the majority of pumped water exits with the exhaust under water, so I can't check it. But the engine is too hot to touch around the casing by the plugs, even after a short run. I was told they never get so hot you can't touch them. Is this true ? I'm worried it will seize up. The mix is 50:1. The engine has never been in salt water so I'm pretty sure the water ways are clear. Any advice please."
