bulletine
The other day I read a post and one person stated there is a improvement when alternator is wired direct to the battery and not the starter.
I have low voltage on my starboard engine volt gauge, the analog meter on the main DC panel shows a bit over 13 volts, the same voltage as the port engine. I will troubleshoot tomorrow or the next day to find out if the alternator should be replaced. The alternators appear to be a Motorola 50 AMP #39049, I have a ARCO #60104 replacement that came with the boat that I will use as a replacement if needed.
I thought as part of the troublshooting process, I would like to change the wire from the starter to the battery. If I should do this, is it good to use a butt connector to extend the wiring to reach the battery, or should I run a new wire. I was thinking maybe a 10 AWG, any thoughts?
Thanks.
Thanks.
