Hi, I have a 1988 powerplay XLT 185. It has a mercruser 350 with an alpha 1. I am having an issue with the alternator belt burning up after a short period of time out on the water. I am not sure why this is happening. When I put a new belt on I loosen both the top and bottom bolts that hold the alternator in place. Slide the belt off and then slide the new belt on. I then I have a friend pull up on the alternator while I tighten both bolts. I then verify when I push down in the center of the belt that it does not flex more than an inch. I then proceed to start the motor and let it run for a bit. Kill the motor and then check for slack again. I have done this 5 times now and I am still burning through the belts. Also after the belt starts to smoke I check for play and the belt somehow has become lose, but when I go to loosen the bolts everything is still super tight and sold. *
Is there something that I am doing wrong? Is there anything I need to replace or align?
My next step was going to be buying new pulleys and a new alternator bracket, but thought I would post online first to see if anyone else has come across the same issues.
Here is the boat I am referring to!
