Alpha1 v8 with 888 outdrive
gearhead
"I just recently purchased a 1
"I just recently purchased a 1987 Chris Craft Scorpion 196. Under the hood it has a what looks like a Alpha1 260 V8. The outdrive says 888 and V8 on it. From everything I've been able to find on the internet this should be impossible, right? My question to people more knowledgeable is. 1) Have you ever hear of such a combination? 2) Could i use any Alpha1 outdrive like one off a 4cyl of 6 cyl engine? Any help of insight would be greatly appritiated."
Are you seeking a solution to
Are you seeking a solution to a problem or just info. on the combination? Need more information from you.
"The serial # on the engine is
"The serial # on the engine is 0A690461 the out drive has 4196949 on it. The out drive on my boat is broken but rebuildable. I want to know if i can use an Alpha1 out drive from a 4 or 6cyl alpha one engine. I also want to know how is it possible to put a 888 out drive on a Alpha1 engine? Also How do i identify my engine? Is is a ford, Chevy, or Chrysler? I'm a Honda mechanic i don't know much about American engines,"
"[b]"The out drive on my b
""The out drive on my boat is broken but rebuildable."
888s were the Pre-alphas that were bolted to the Ford V8s,....The gear ratio should be the 1.5/1....
"I want to know if i can use an Alpha1 out drive from a 4 or 6cyl alpha one engine."
No,.... The Gear Ratio will be All Wrong.......
"I also want to know how is it possible to put a 888 out drive on a Alpha1 engine?"
While there are a few issues to watch for,....
The Alphas,+ the Pre-Alphas are Direct Interchangeable drives.....
"Also How do i identify my engine? Is is a ford, Chevy, or Chrysler?"
Ayuh,........ I'm guessing it's a Chevy........ Distrubuter should be at the Rear of the motor......
Fords have it in the Front......
And,.......
Chrylers have Never been used by Mercruiser......."
"Thank you for the info! From
"Thank you for the info! From what you said, i can either rebuild my 888 or find an Alpha1 out drive from a V8 alpha engine and it should bolt up to my Alpha1 engine. The Alpha1 out drive has to come from a V8 because of the gear ratios. My engine has the distributor on the back of the engine so its Chevy motor. I really appreciate you taking the time to explain things."
