Alpha One Trim Ram / Cylinder Question
Warui
Hi All,
I have an Alpha One Gen II and have trim rams / cylinders that have failed.
Part Numbers 815935-1 and 815954-1.....
Best I can tell these tubes are 15 7/8"
I can get the Gen I rams / cylinders (14034-1 and 14035-1, with tubes measuring 16 3/16") which use the rubber bushings, washers and nuts. These bushings and washers will be too thick for my current existing front and rear anchor pins which use little washers and c-clips.
Here are my questions....
Does anyone know which front and rear anchor pins I can use, part number etc? I thought about trimming the edges of the bushings down to get them to fit but I think I will be metal to metal if I do that.
And, will the length of the rams be a problem in any way?
Thank You So Much In Advance!!!
Ayuh,.... What, Exactly is wrong with the original rams,..??
They are rebuildable ya know....
If yer's are so trashed they can't be rebuilt,...
Find a set of the Right rams...
Cobbin' in what you've got is only goin' to be constant Problems...
