the side fitting for the gimbal bearing usually will take 10-15 pumps to see it exit the bearing . Drive must be removed to see this. The missing upper grease fitting can be installed very easily. I install them on all my customers boats. Lower fitting is no longer used
I’m still not clear where that grease is going in that one fitting?
How would I add that upper grease fitting you mentioned? There seems to be no access cover on top. Why the hell would they not put lubrication points in these pivot points? That lower steering pivot does not need lubrication? No way to lubricate it?
Also, I found a tear in the upper boot while poking around back there this morning. And I note the boat is taking on water while in operation and I have to run the bilge pump every so often. I left the boat docked in the lake earlier this summer on vacation and it was taking on significant water while docked. 3 or 4 hours later I went out to check the boat that night and the below deck ski storage was nearly full. Pumped it all out and returned early the next morning to find the same thing. Had to pump a ton of water out. If I left it in the water 12 hours the damn think might be on the bottom of the lake.
I knew I had problems back there but I’ve wanted to wait till the end of the season to fix it. Am I gonna ruin it if I keep running it in this condition? Should I stop running the boat till I fix all this mess? I don’t want to ruin it, but I was hoping to wait till the end of the season like I said. It has been running good otherwise. I don’t have milky oil in the foot.
With your experience, is there a kit I can buy with all the parts I need to replace. Gimball bearing, boots, and water pump impeller? You joints? I don’t want to keep taking this thing apart throwing parts at it. I want the damn thing to work. I don’t have much money in the boat itself but all this other crap I’ve had to fix is starting to add up as you might imagine. Boat now has about 545 hrs. on the clock. I’m also not running it around wide open all the time.
Is there a manual specific to this 1995 motor/outdrive setup? Like I said the SELOC manual is all over the place and doesn’t seem to provide much detail. But better than nothing. The Serial# on the engine ID plate is F360605.
