Hi,Im in the middle of overhauling my gbox on my Mercruiser Alpha One.Reason was water in the oil,and excessive slop in the propellor shaft.after pulling apart and all the usual stuff,Im reassembling using all new bearings and seals,original shims back where they came from.In the GLM parts book,I noticed a spacer washer that went on the prop shaft before the reverse gear.I thought that would solve my excessive end float of the propellor shaft..When it arrived I found it was the wrong size to fit snug inside the reverse gear clutch dogs,[where a shim washer should have fitted].so the question is,how do you adjust the endfloat?Ive got the w/shop manual,and theres no mention of this.I have one millimeter endfloat.is that ok?I have also shimmed both the forward and reverse gears to get correct backlash on the driveshaft.Ive had to put a shim between the reverse gear and the bearing it sits in[which helped a bit with the endfloat] to get the backlash down to a reasonable level.[was excessive].Also,is the forward gear bearing preloaded by the thrust of the prop pushing forward?Ive also read your online w/shop manual which I downloaded.My diveshaft is the type thats thrust upward[no preload pins]./Im using home made tools,wish I had the proper gear.Any advice appreciated
