1973 Browning Marine
Went down to a river system close to my shop to water test boat. Everything went well for about two hours. Was not familiar with the area but the guy who went with me assured me there was plenty of water. Anyway, was going upstream and struck a rock travelling about 20-25 mph. Immediately tried to raise drive and again struck another rock with prop. Turned boat with drive trimmed up as far as I could get it and started downstream and away from the area. I knew that I had done damage. The drive and prop were still spinning and was able to limp back to the dock area. Shut off engine and trimmed up as far as possible. Immediately saw mushroomed prop and proceeded to load boat on trailer. After loading, looked at the lower unit and to my horror (lol) could see a hole on the front side of the lower unit about parallel to the center line of prop shaft. Obviously, the lower unit housing is junk as well as all of the internals. Pulled the lower unit off of boat with upper unit still attached to boat. Took off the bearing cap on upper unit and saw that there was still oil in upper unit gear housing but had some water droplets mixed with the oil. The gear oil still looked green but there was water intrusion. At the time, I was not aware of how much damage that I had done. I did not see any oil slick when I struck. I knew the aluminum prop was shot but when returning to ramp, there was very little vibration from the damaged prop. However, after spinning prop on trailer, I could see that the prop shaft was untrue. (not running perfectly straight) My worry is this: I travelled after the initial impact about two miles back to loading ramp not knowing the extent of damage. Like I said, there was still oil in the upper drive. Actually looked quite full when I pulled the bearing cap. I also felt the upper drive housing right after I loaded up boat thinking I probably heated everything up but that was not the case. It was actually cool to the touch. I know that I will be replacing lower unit without question. The question is this: How do I know how much damage was done to the upper housing and where should I start investigating? I have alot of questions but have not gotten far enough to do any visual inspection of the upper gears, etc. I am in the process of draining the upper unit of oil as I said with the bearing cap removed and the lower unit removed. Any suggestions or advice would be greatly appeciated at this point. bummed out, Tom
