I hit a rock on July 3rd and had to be towed back to the boat landing.
The propeller is damaged and it broke of the majority of the skeg plate.
I dropped the lower unit today. The propeller shaft appears to be bent. The drive shaft will not rotate by hand. I will probably look for a used lower to get back on the water quicker.
What should I check on the upper?
Thank you
Thank you
