Octoberon59
I have a 2004 alpha 1, generation 2 drive, both external wire's on the trim limit and senders have broken, so I plan to change both, however when I traced the wiring inside the engine bay I found that the bullet connectors weren't connected to the trim pump, would anyone have a wiring diagram so I can reconnect and have the trim limit sender working as it should.
The drive does raise and lower but doesn't stop at the recommended limit of 20 and 3/4 inches.
