Alpha One Gen 2 Stern Drive Shift Shaft Bushing
micboy
Hi, All
I needed to install this OEM kit part number 23-806036A1, however I noticed that the seals are bigger then the brass bushing..do these go inside the brass were this have the reassess.
Does someone have a good installation instructions..
Photo below
Thx
Mic
What you have there is the upper and lower (vertical) shift shaft bushing and seal for the GIMBAL HOUSING.
Are you aware of this? Or did you want the outdrive shift shaft seal?
I have copied the instructions but when I up load them the image is too small to read.
I HATE THIS ATTACMENT EDITOR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If someone could assist me on inserting it into the reply that would be nice.
And no software instructions, easy to understand layman instructions PLEASE!!
Hi Kghost
Yes this is for the bell housing attched as I found a light presence of salt near the **** cable..
I can not upload the instructions thru here, send me a personal message with a email adress and i will send it to you.
Also take note, The location of the bushings is very very important. If the lower bushing is too high in the housing the vertical shift shaft will not engage the shift shaft in the outdrive properly. VERY IMPORTANT!!!
I have seen the bushing work its way upward and cause shifting problems. If the hole is too loose then once the hieght is correct use a center punch and "pean" the housing around the busghing to secure the bushing. Not too hard but enough to keep it from moving. Also a good locktite.
