Lesley Dingwall
Hi,
My alpha 1 leg will trim up but will not trim down. I have disconnected the four lines to the leg and hydraulic fluid flows from one on each side when the switch is activated and the two remaining lines allow the flow of hydraulic fluid when the other switch is activated. The motor runs when both switches are activated. I have topped up the hydraulic fuid and and bled the system.
IT DOES NOT SEEM TO BE A PROBLEM WITH THE SWITCH OR THE PUMP, OR IS IT?
Any suggestions would be appriciated.
