ALPHA 1 SS Question
ryan00tj
"After comparing the parts bre
"After comparing the parts breakdown for the Alpha 1 and Alpha 1 SS, the only difference is the lower case, shorter driveshaft, shorter water tube, water restrictor, different lower shift shaft and intermediate shift shaft. All other parts seem to be the same as the Alpha 1. Of course the upper has HD gears. Those of you that know the SS, are there any other parts that are specific to the SS only? I found that all parts are available, except the case, but expensive. Thanks"
"Ayuh,.......
You've go
"Ayuh,.......
You've got it Right,........
The Problem is,....
There aren't any Cases........
And,........
It would co$t more than the price of a Bravo to Build 1,.....
If you could find a Case in servicable condition........."
