Ok, I really hope someone can guide me in the right direction and this is an easy fix. I have a 1987 27' sport fisherman with I/o mercruiser twin 260 with alpha 1 outdrives.(electronic shift) here is the issue. I go into forward with both and put in neutral and it stays in forward. No neutral. It does the same thing in reverse. Basically I can't go from forward to reverse Ir vice versa. Unless I cut off the enginses turn back on and put it in the other gear. Sometimes it works great. Goes forward to reverse and vice versa without issues. Then sometimes I go from forward to reverse and the engine stalls. I'm very frustrated and need some insight, wondering if it's electric or mechanical any suggestions would be greatly appreciated
