michaelduanehughes
Hi All,
This is my first post here. This is a great forum and it has taught me a lot. I have searched this forum so much but still can not fix my problem. I have a 2010 mercruiser alpha 1 o/d on a 19ft bayliner bowrider. About 2 years ago the the trim indicator on the dash stopped working but the out-drive still went up and down fine. I would be able to hear the difference in the motor when it was all the way up or all the way down. Last season my drive got stuck in the up position. I winterized it and just started it up today. Luckily our winter was very mild.
Tried jumping on the o/d while pushing the trim button down - nothing
Replaced both solenoids - nothing
Filled up the tank with trim fluid - nothing
When i press the trim button up and down the motor runs but will not go down.
I tried to remove the hydrolic lines from the pump to switch them to see if I could get it down that way, the up hose (left side of the pump) quick connect came off fine. The right hose ( down) will not come off for anything. I'm assuming that's because its pressurized because the o/d is in the up position?
Am I doing anything wrong to try to get this hose off?
Is there anything else I can do?
All electrical connections seem to be working. I just starting to get frustrated. I don't want to blindly replace the whole pump/reservoir assembly or the cylinders if I don't need to do all of that.
Any help would be much appreciated!!!
THANK YOU!!
THANK YOU!!
