Re: Alpha 1 gen 2 loosing fluid
used a old weed wacker gas tank, added a metal tire valve to add air, and a 3 foot hose and old fitting.
Fill up the tank with gear lube screw in the fitting to the lower plug hole and hit it with compressed air about 2 psi in goes the gear oil fast like. I make sure i crack the cap before the lube is gone in the tank.
Add a more oil more air till the drive is full.
For the tester i just used a old gauge off a compressor, in one hole, and made up a tire valve and a old fitting for the other hole.
When the drive is holding air, wiggle the shift shaft, and if air escapes you know you found the problem. Or you could pressure test it with oil in it. You will see where the oil comes out.
One other thing if new washers were not used when the oil was changed that could be the problem.
Now if you have it all apart to change the bushing wouldn't it make sense to go ahead and change out the impeller ??????
The bushing is included in alot of impeller kits.
