Alpha 1 gen 2 impeller replacement cost
lscott
What should a shop charge to r
What should a shop charge to replace the impellor? I have gotten two different prices $150 and $275. 2000 5.0 alpha 1 gen 2 drive
No issues just preventative replacement
I was told it didnt need the housing because it was metal in the gen 2
"When you consider that they&#
"When you consider that they'll replace the drive fluid (about $30), the impeller and gasket (about $30), the O ring (about $1.00),throw in an hour of labour and viola, your at $150.00"
Sierra shows $45.99 for 18-321
Sierra shows $45.99 for 18-3214
Remove drive and split
2 Qts of drive oil and pump to put it in
replace pump
Re-install and test run
Add yours or his labor.
Thanks for the replies....
I
I am handy so to speak but have zero knowledge of outdrives. I have researched the procedure and agree its pretty straight forward if you have done it before. I was wondering why so much difference in price.
I am finishing my basement and trying to finish up before warm weather comes so all my extra time is going into this. thats why I am taking it in even though I need to learn how to do it myself.
"If your doing all that extra
"If your doing all that extra work, yea it would be alot easier to let someone do it and you read up for next time.. Good Luck"
See if you can find a local mo
See if you can find a local mobile marine mech and have him come over and do it and watch to see just how easy it may be or not for you.
Same price and you get to watch....
