Alpha 1 2nd gen bell housing
Paul57
I've acquired a really clean, less than 100 hours 1998 Sea Ray 185 and she's leaking at the interface of the transom plate and the gimbal housing. A modest leak if in the water or if the bilge in the engine bay is partly filled with water. This means the transom core is in jeopardy and likely getting wet. I've replaced the bellows, hoses and drive seals recently, shortly after purchase, as they showed signs of cracking, even with little use, so I just replaced them.
I'm an SAE mechanic for some 30 years, though little boating experience, finding this boat in this condition, with this few hours was just a deal I couldn't pass on. I'm fully equipped to pull the engine and have had the drive off already. I know I need to pull the drive again, plus the ring and housing, then the engine and the transom plate to get at the transom. I have a gantry tall enough to yank the engine and roll the boat out from under.
My main questions are, what types of special tools will I need to get the housing off? I figure I'll need an alignment tool for reassembly, I have the bellows ring driver and expander, but I'm seeing some odd stuff that I'm wondering about, such as the shift cable nut, gimbal ring pivot bolts, etc.
I'm also wondering about pulling the engine. If I see things right, the transom plate also serves as the rear engine mount. Wouldn't it be possible to block the engine up, drop the Y pipe and get access to the transom plate nuts, without engine removal? I'd have to address any core issues from the outside, which I think is possible, as I don't expect much rot, given the hours on this boat.
I'm just wondering if I've bit off more than a skilled automotive mechanic can attempt. Simply, is this a project a serious car guy can do or will I need a $1,000 in special tools to get it done. I have a buddy that's a boat guy and he says it's doable, but a big job for a novice. He's the one that will fix any transom core damage. He has a home made tool that will remove any rotten plywood, between the skins around the bolts and cut out, which he'll backfill with thickened epoxy. When this is cured, he'll (who am I kidding) I'll recut the cutout and bolt holes.
